【求助帖】关于CAN总线驱动直流无刷电机的问题
13820
2019-09-15
小白入坑,想用can控制电调驱动无刷,板子是A板,M2006动力系统。波特率是按例程调的,想问下大佬们为啥发出去跑不起来呢?还是我理解上出了问题。
int main(void)
CanTxMsg TxMessage;
LED_Init();
delay_init(168);
CAN1_Mode_Init(CAN_SJW_1tq,CAN_BS2_4tq,CAN_BS1_9tq,3,CAN_Mode_Normal);
while(1)
TxMessage.StdId=0x200;
TxMessage.IDE=CAN_ID_STD;
TxMessage.RTR=CAN_RTR_DATA;
TxMessage.DLC=8;
TxMessage.Data[0]=0x13;
TxMessage.Data[1]=0x13;
TxMessage.Data[2]=0x13;
TxMessage.Data[3]=0x13;
TxMessage.Data[4]=0x13;
TxMessage.Data[5]=0x13;
TxMessage.Data[6]=0x13;
TxMessage.Data[7]=0x13;
CAN_Transmit(CAN1, &TxMessage);
u8 CAN1_Mode_Init(u8 tsjw,u8 tbs2,u8 tbs1,u16 brp,u8 mode)
GPIO_InitTypeDef GPIO_InitStructure;
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;
#if CAN1_RX0_INT_ENABLE
NVIC_InitTypeDef NVIC_InitStructure;
#endif
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0| GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource0,GPIO_AF_CAN1);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource1,GPIO_AF_CAN1);
CAN_InitStructure.CAN_TTCM=DISABLE;
CAN_InitStructure.CAN_ABOM=ENABLE;
CAN_InitStructure.CAN_AWUM=DISABLE;
CAN_InitStructure.CAN_NART=DISABLE;
CAN_InitStructure.CAN_RFLM=DISABLE;
CAN_InitStructure.CAN_TXFP=DISABLE;
CAN_InitStructure.CAN_Mode= mode;
CAN_InitStructure.CAN_SJW=tsjw;
CAN_InitStructure.CAN_BS1=tbs1;
CAN_InitStructure.CAN_BS2=tbs2;
CAN_InitStructure.CAN_Prescaler=brp;
CAN_Init(CAN1, &CAN_InitStructure);
CAN_FilterInitStructure.CAN_FilterNumber=0;
CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_Filter_FIFO0;
CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
CAN_FilterInit(&CAN_FilterInitStructure);
CAN_ITConfig(CAN1,CAN_IT_FMP0,ENABLE);
NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX0_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
#endif
return 0;
int main(void)
CanTxMsg TxMessage;
LED_Init();
delay_init(168);
while(1)
TxMessage.DLC=8;
#endif
#endif
return 0;
