【求助帖】如何能够提高视频回传的清晰度?
4330
小弟现在手上有一个RM,正在利用开源代码接收视频,但是效果不清晰,请问如何调整参数能够提升清晰多,多谢啦多谢多谢多谢。
#!python3
import sys
sys.path.append('../decoder/ubuntu/output/')
sys.path.append('../../connection/network/')
import threading
import time
import numpy as np
import libh264decoder
import signal
from PIL import Image as PImage
import cv2
import opus_decoder
import pyaudio
import robot_connection
import enum
import queue
class ConnectionType(enum.Enum):
WIFI_DIRECT = 1
WIFI_NETWORKING = 2
USB_DIRECT = 3
class RobotLiveview(object):
WIFI_DIRECT_IP = '192.168.8.202'
WIFI_NETWORKING_IP = '192.168.1.101' #写死地址即可
USB_DIRECT_IP = '192.168.42.2'
def __init__(self, connection_type):
self.connection = robot_connection.RobotConnection()
self.connection_type = connection_type
self.video_decoder = libh264decoder.H264Decoder()
libh264decoder.disable_logging()
self.audio_decoder = opus_decoder.opus_decoder()
self.video_decoder_thread = threading.Thread(target=self._video_decoder_task)
self.video_decoder_msg_queue = queue.Queue(64)
self.video_display_thread = threading.Thread(target=self._video_display_task)
self.audio_decoder_thread = threading.Thread(target=self._audio_decoder_task)
self.audio_decoder_msg_queue = queue.Queue(32)
self.audio_display_thread = threading.Thread(target=self._audio_display_task)
self.command_ack_list = []
self.is_shutdown = True
def open(self):
if self.connection_type is ConnectionType.WIFI_DIRECT:
self.connection.update_robot_ip(RobotLiveview.WIFI_DIRECT_IP)
elif self.connection_type is ConnectionType.USB_DIRECT:
self.connection.update_robot_ip(RobotLiveview.USB_DIRECT_IP)
elif self.connection_type is ConnectionType.WIFI_NETWORKING:
#robot_ip = self.connection.get_robot_ip(timeout=10) by hrh
robot_ip = RobotLiveview.WIFI_NETWORKING_IP
if robot_ip:
self.connection.update_robot_ip(robot_ip)
else:
print('Get robot failed')
return False
self.is_shutdown = not self.connection.open()
def close(self):
self.video_decoder_thread.join()
self.video_display_thread.join()
self.audio_decoder_thread.join()
self.audio_display_thread.join()
self.connection.close()
def display(self):
self.command('command')
time.sleep(1)
self.command('audio on')
time.sleep(1)
self.command('stream on')
time.sleep(1)
self.video_decoder_thread.start()
self.video_display_thread.start()
self.audio_decoder_thread.start()
self.audio_display_thread.start()
print('display!')
def command(self, msg):
# TODO: TO MAKE SendSync()
# CHECK THE ACK AND SEQ
self.connection.send_data(msg)
def _h264_decode(self, packet_data):
res_frame_list = []
frames = self.video_decoder.decode(packet_data)
for framedata in frames:
(frame, w, h, ls) = framedata
if frame is not None:
frame = np.fromstring(frame, dtype=np.ubyte, count=len(frame), sep='')
frame = (frame.reshape((h, int(ls / 3), 3)))
frame = frame[:, :w, :]
res_frame_list.append(frame)
return res_frame_list
def _video_decoder_task(self):
package_data = b''
self.connection.start_video_recv()
while not self.is_shutdown:
buff = self.connection.recv_video_data()
if buff:
package_data += buff
if len(buff) != 1460:
for frame in self._h264_decode(package_data):
try:
self.video_decoder_msg_queue.put(frame, timeout=2)
except Exception as e:
if self.is_shutdown:
break
print('video decoder queue full')
continue
package_data=b''
self.connection.stop_video_recv()
def _video_display_task(self):
try:
frame = self.video_decoder_msg_queue.get(timeout=2)
break
print('video decoder queue empty')
continue
image = PImage.fromarray(frame)
img = cv2.cvtColor(np.array(image), cv2.COLOR_RGB2BGR)
cv2.imshow("Liveview", img)
cv2.waitKey(1)
def _audio_decoder_task(self):
package_data = b''
self.connection.start_audio_recv()
buff = self.connection.recv_audio_data()
if buff:
if len(package_data) != 0:
output = self.audio_decoder.decode(package_data)
if output:
try:
self.audio_decoder_msg_queue.put(output, timeout=2)
break
print('audio decoder queue full')
continue
package_data=b''
self.connection.stop_audio_recv()
def _audio_display_task(self):
p = pyaudio.PyAudio()
stream = p.open(format=pyaudio.paInt16,
channels=1,
rate=48000,
output=True)
try:
output = self.audio_decoder_msg_queue.get(timeout=2)
break
print('audio decoder queue empty')
continue
stream.write(output)
stream.stop_stream()
stream.close()
def test():
robot = RobotLiveview(ConnectionType.WIFI_NETWORKING)
def exit(signum, frame):
robot.close()
signal.signal(signal.SIGINT, exit)
signal.signal(signal.SIGTERM, exit)
robot.open()
robot.display()
if __name__ == '__main__':
test()
#!python3
import sys
import threading
import time
import numpy as np
import signal
import cv2
import opus_decoder
import pyaudio
import enum
import queue
WIFI_DIRECT = 1
WIFI_NETWORKING = 2
USB_DIRECT = 3
def open(self):
if robot_ip:
else:
return False
def close(self):
def display(self):
time.sleep(1)
time.sleep(1)
time.sleep(1)
print('display!')
res_frame_list = []
package_data = b''
if buff:
try:
break
continue
package_data=b''
try:
break
continue
cv2.waitKey(1)
package_data = b''
if buff:
if output:
try:
break
continue
package_data=b''
channels=1,
rate=48000,
output=True)
try:
break
continue
stream.close()
def test():
robot.close()
robot.open()
robot.display()
test()
